http://www.boostcaraudio.com/index.asp?PageAction=VIEWPROD&ProdID=513
GM-X962 760 Watt 2 Channel Amplifier
Delivering 760 Watts (peak) of power, the GM-X962 is a fearsome weapon in the war against wimpy music. This 2-channel amplifier features Pioneer's PWM regulated MOSFET power supply that is highly efficient, yet stunningly ferocious. The oversized screw-type power/ground terminals and screw-type speaker terminals allow you to use larger-gauge speaker wire. Bigger wire, more current flow, better sound. And, a built-in selectable crossover makes the install easier and faster. Now, even short trips to the store will be memorable. Hey, is that the last of the milk?
Features
PWM Regulated MOSFET Power Supply
Bridgeable 1/2/3 Channel Capability
Balanced Isolator Input Circuit
Oversized Screw-Type Power/Ground Terminals
Screw-Type Speaker Terminals
RCA Inputs
Hi-Volt Input Level Control (200mV-6.5V)
Selectable Crossover: 80Hz, -12dB/oct. (LPF)
Specifications
Continuous Power (14.4V): 125Wx2 (4 ohm), 190Wx2 (2 ohm), 380Wx1 (4 ohm)
Max Power (14.4V): 250Wx2 (4 ohm), 760Wx1 (4 ohm)
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion: 0.008% (1kHz, 4W)
Signal-to-Noise Ratio: 100dB (IHF-A)
Dimensions: 11" x 2-5/16" x 12-3/4"
