Selling everything in my sig. Pics will be up in the next 2 days or so, I work 11pm to 7am so dont have a ton of free time. Times gettin hard again, plus I want to start saving to build a better system, not just something to lay over.
Prices are as follows.
Pioneer 6000UB-$120 shipped
Bought brand new in Feb 08 from Crutchfield, had ground noise issue, sent it back since it was still under warrenty, have not had any issues since then. Works perfect, faceplate had a little wear and tear on it, but nothing bad. Awesome HU for someone looking for USB support.
MTX 502 amp--$70 shipped
Bought on here, works perfect, underrated, does around 125w per channel at 4 ohm. Have had it pushing a set of PG RSDs for the last month or so very well.
MTX 6500d--$100 shipped
Again, purchased on here, underrated as well. Does a solid 750 to 800w at 2ohm. Nice little Class D sub amp if your looking to push a single sub or a pair of low power ones. Very comparable to a Kicker 750.1, but cost much less. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Both amps together,
PG RSD 6.5s--$55 shipped
Not much to say here, were purchased around a month ago from Audiosavings, work perfect. One of the tweeters has a small short that came from the factory like that, but im sure a shot of solder or hot glue will fix that. I have them secured in their surface mount cups and dont have any issue with it, but I like to make people aware of what their buying. Crossovers have a couple of scratches from being mounted in my kick panels, but otherwise the set is perfect.
Single run 0/1 Welding wire (black)--$60
Length, im not positive, ill measure it when I get it out of my car, but im sure its over 20 feet. Has worked very well for me, pretty flexable as well.
All items will be shipped via USPS, and I will have some pics up in the following days as I remove the items currently installed in my car, thanks.
Both amps together,
