J joelowrider 10+ year member Senior VIP Member 293 0 owensboro, ky Jul 22, 2007 #1 this is for a s-10 2 12in bl @34 hz @2.2 cubes each Click to read more...
kpozr2 10+ year member CarAudio.com Elite 1,775 0 Iowa CIty, IA Jul 22, 2007 #2 nice! lets see it in the truck! what year? ext cab?
negativezeroz 5,000+ posts Nothing Is Promised 5,020 2 -salad fingers- Jul 22, 2007 #3 Looks good so far. Only "problems": Top picture- the port doesn't look straight Why didn't you round them cornerz? Just curious. I'm sure you'll be fine it's just a cautious move to round them off.
jmanpc 5,000+ posts CA.com Nostalgist. 16,929 8 Jacksonville, Fl Jul 22, 2007 #4 yeah, you need to make sure the port is straight, and also, you couldve gotten away with about half as many screws. Other thank that, lookin alright.
OP J joelowrider 10+ year member Senior VIP Member 293 0 owensboro, ky Jul 22, 2007 Thread Starter #5 the subs get here wensday and my amp will be here friday so next weekend i hope to be done the port is square and straight what do you mean less screwws i figured more screws and glue the better
mazdakid 5,000+ posts CarAudio.com Veteran 11,667 17 illnoise Jul 22, 2007 #6 screws are pretty much just there to hold it in place until the glue dries. i just use clamps instead
OP J joelowrider 10+ year member Senior VIP Member 293 0 owensboro, ky Jul 22, 2007 Thread Starter #7 you dont use any screws
Max_Power 10+ year member ^ From a Hairdryer ^ 2,189 1 Toledo, Ohio Jul 22, 2007 #8 you dont have to. properly glued joints are stronger than the surrounding wood
B BrianChia 10+ year member CarAudio.com Elite 1,294 0 Knoxville/Nashville TN Jul 23, 2007 #9 Screws have their uses in some cases. A glued joint can separate if the MDF surface tears off in layers (which it can be prone to do sometimes) and that wouldn't be as likely to happen with a screwed and glued joint.
lamont1 10+ year member Senior VIP Member 275 0 Hattiesburg/picayune,MS Jul 23, 2007 #10 i say box looks good bro, as long as its straight put how many you want.the more or less screws the better
OP J joelowrider 10+ year member Senior VIP Member 293 0 owensboro, ky Jul 23, 2007 Thread Starter #11 thanks it looks bent in the picture i dont know why but I put a squre on it and its good
