*PICS* 7 cubes box 2 15"s
86yota
I got to redo the port, I juss figured out I tuned it to 43hz, Ill pass on that one..so somewhat tearing it apart tomorrow to make an L port for it and tune it to 33hz. Covering it hopefully before the end of the weekend, and making some panels for the trunk/amp. Will take pics of that process as well! This is my 4th box I am getting better, but its not perfect.
To tell you the truth I didnt even think about that untill now. Im juss going to go as far back as I can with the port I guess, Does it matter how far away I am from the back wall as long as Im not against it?
Could I not play normal rap music on it? I have 120sq in of port..
you can play all music lol
but it wont get as low as box say tuned to 33hz. but you will definitly hear it but not with as much authority //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
plus rap music usually stays in the 40's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
your supposed to plan your box BEFORE you build it...you could always keep it as your SPL box, but if you want a lower tuned box, you need to make a new box. once you disassemble that box, its junk, AKA unreusable
I actually managed to get the front peice off without destroying anything, that let me take the old port out, and I reused the front peice and juss took some length off it to make it 22" long, all I got to do now is make a new front peice today that makes the port 3.5" wide, and I will be tuned to 35hz. It should all go back together nicely, I juss got done cutting/painting the port at 6:45 AM lol
If you could take your box apart that easy, it's not strong, nor is it well constructed. Build a new box.
Changing internal volume ALSO changes tuning frequency. That also might be too small of a port for two 15s.
86yota
86yota
Gat town, TN
86yota
