ok, simple: have a machine shop make you a "top plate extension". You know your top plate ID, you know your basket mounting flange ID.....make the plate extension out of 18mm low carbon steel with the same ID as your motor's top plate and OD about 2-3mm shy of the basket mounting flange ID. That leaves a little play room for the basket to mount around it. That plate will need the same primer and glue used on most motors. Now your coil center will be higher than before as your gap will be taller, but the bottom of the gap still remains at the same height from the top of your back plate. You can effectively use an 18mm taller coil and still have the same rearward stroke capability. Your coil ww center will sit 9mm higher and your coil would be overall 18mm taller than the previous coil. same rearward clearance. This would allow you to use larger gauge flat wound wire to achieve your desired final DCR with coils wired in series.
another way to change it up would be to slowly screw in bolts that are longer than the top plate is thick. make sure you put cardboard around the pole piece to be able to remove the top plate from the motor as soon as it shifts. take that to your machine shop and have them bore the ID out to whatever you choose, so long as it is smaller than the ID of your magnets. this allows you to use a pair of coils with more winding layers. Either way, make sure you get a pair of coils that are bifilar wound. Do the same thing with the top plate extension ring to make it mate up to the top plate. now that both pieces are off the motor, you can have your machine shop attach copper or aluminum shorting rings below and above the top plate assembly. ask your new cone/surround provider how many different surround options you have as far as compliance goes. it's way better to build up your compliance with surround foam thickness than to stack a number of spiders together. Let the spider do what it does best; keep the coil centered. this way you also have a relatively broken-in subwoofer after just a few minutes of high excursion use and your surround will basically remain the same throughout the life of the subwoofer. play it without a dustcap first to see if your need to add any mass around the former, above the cone joint. if so, add.....if not, glue the dust cap on and have a fun summer.
