Sold Phoenix Gold Tantrum 400.4
Shinju
The amplifier work perfect and are in pretty nice shape with very few blemishes, No end caps though.
Specs:
Tantrum 400.4
Into 4 ohms Stereo @ 12.5 Vdc (IASCA/USAC) . . . .20 x 4
Into 4 ohms Stereo @ 14.4 Vdc . . . . . . . . . . . . . . . .50 x 4
Into 2 ohms Stereo @ 14.4 Vdc . . . . . . . . . . . . . . .100 x 4
Into 4 ohms Bridged @ 14.4 Vdc . . . . . . . . . . . . . .200 x 2
Recommended Fuse Size . . . . . . . . . . . .25A x 2 ATO style
Dimensions without Endcaps . . . . .11.75L x 10.0W x 2.35H
Dimensions with Endcaps . . . . . . .16.75L x 10.0W x 2.35H
(Other common specs per manual for both amplifiers)
Common Specifications
Frequency Response . . . . . . . . . . . .±1dB, 20Hz to 20kHz
Signal to Noise Ratio (A-weighted) . . . . . . . . . . . . .>100dB
Input Sensitivity . . . . . . . . . . . . . . . .100 millivolts to 4 volts
Crossover Frequency . . . . . . . . . . . . . . . . .40Hz to 800Hz
Crossover Slope . . . . . . . . . . . . . . . . . . .18dB per Octave
Bass Boost . . . . . . . . . . . . . . . . . . . . .0 to +18dB @ 45Hz
DC Input Voltage Range . . . . . . . . . . .10 volts to 15.5 volts
Typical Current Draw at Idle . . . . . . . . . . . . . . . . .
Minimum Bridged Load . . . . . . . . . . . . . . . . . . . . . .2 ohms
Minimum Stereo Load . . . . . . . . . . . . . . . . . . . . . . .1 ohm
Maximum Power Load . . .4 ohms bridged or 2 ohms stereo
135.00 shipped CONUS
Tantrum 400.4
Shinju
Shinju
Seattle
Shinju
