Dozy_production
Poel
I would with at least the w6v2.I wouldnt go as far as sayin that the RSD is on par with the w6v2 or the IDMAX. But it is a good sub
Well, since cot jones thinks they **** I might just buy one. I have been thinking about it anyway, but I am fairly certain that if you go through life doing exactly the opposite of what cotjones says you will be pretty dam successful.the rsd sucks imo
I haven't heard a w6v2 but it is definately on par with the Idmax. My buddy has one and this sub sounded just as good as his Idmax and even hit a little tighter if you like that in your bass. Some people don't but I do.I would with at least the w6v2.
Not all that crazy. At most, you'd see a 3db gain from doubling your power. Now if you doubled the number of subs AND power, that's another story.Dang man, my car is very loud with just this one 12 at about 500 watts. I am wonder how crazy good it would be with twice the power running to it.
Glad to see the RSD putting a smile on another person's face.
So do you have the single or dual voice coils? I only ask because I don't see the duals as much. I wondered why.
I have the dual voice coils.
I wish I bought a stronger/better amp though. Don't get me wrong, they sound good. But, I think they would be even better with more power coming from a better amp.
Oops, i had sigs turned off. I had accidentally turned them off when i had to turn off avitars. Half of peoples avitars here are not suitable for work!//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifIf he's using the amp in his sig and the subs are wired to 1 Ohm at the amp, then probably 700-750Wrms each.
^correct.If he's using the amp in his sig and the subs are wired to 1 Ohm at the amp, then probably 700-750Wrms each.
I have the duals aswell. I like the duals because with two of them, it allows you to wire them down to one ohm.
PA A2400DB = 1800 watts @ 1 ohm = 900 watts per sub, = amazing budget SQL //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
