First contender.
The Famous M25
Very underrated little SQ amplifier with loads of power in a small foot print.
The amp is in over all decent cosmedic condition few rust spots here and there but being that it was from 1993 and use its not as bad as other amps I have seen.
I just replaced all the Term screws with brand new ones. You can run this amp in 3 way mode (Triple Darlington).
Spec's
2 x 25W @ 4 ohms (12V)
2 x 65W @ 4 ohms (14.4V)
2 x 70W @ 2 ohms (14.4V)
2 x 70W @ 1 ohm (14.4V - Current limited)
1 x 140W @ 4 ohms bridge (14.4V)
1 x 140W @ 2 ohms bridge (14.4V - Current limited)
Fuse: External 30A
Manufactured in 1992-1995
2 ohms bridged or 1 ohm stereo operation REQUIRES cooling fans
100.00 shipped firm
Second Amp.
Phoenix Gold XS 2300
Do not let the small size fool you, This lil amp put out a solid 300 rms at 2 or 4ohm mono. This amp is perfect for someone with little room to have a decent power amplifier to run a set of comps or subwoofers.
The amp is in great condition and perfect working order. It is missing one terminal screw for the speaker out but I'll have a replacement one on it before it shipped to the buyer.
Spec's
2 x 75W @ 4 ohms
2 x 150W @ 2 ohms
1 x 300W @ 4 ohms bridge
Can run 1 ohm stereo and 2 ohm Mono per info on Phoenix Golds old resource website.
100.00 shipped firm
The Famous M25
Spec's
Fuse: External 30A
100.00 shipped firm
Second Amp.
Spec's
2 x 75W @ 4 ohms
2 x 150W @ 2 ohms
100.00 shipped firm
