that pic is showing 8ohms?OK changed fuse to 80A. double checked wiring. exactly like this http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/1DVC_4-ohm_2ch.jpg
any other ideas?
edit: working again, but did go into thermal once for 10-15 seconds. was playing for 30 minutes. feels like it happens on bass heavy songs.
let us know what happens....Sub and enclosure is less than 3 months old.
Will put gain down to half and bass boost to 0 for a couple of days and see if it makes a diff
thisthen since Shinju said he has 1 ( IIRC ) wire it at 2 ohms and get back to us //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ventilation is not an issue as right now it's attached to carpet in my hatch (toyota matrix). **** load of clearance space and temp is below 0 right now..Those amps will do 2 ohm but they require to be well ventilated as they start to generate more heat.
Maybe your sub is on the verge of blowing and its causing a dead short, do you have a DMM to check each coil to see?
Also you will need to set your gain better and also using a DMM as well.
