PG Xenon 600.1
I remember correctly xenons would put out the same amount of power in 1 ohm as it would at 4 ohm, so running it at 4 ohm would be the best since you won't get any more power out of it.
4 ohms will be best for that amp. It will however, put out more power the lower the impeadence. Even though it has the Xe.Load, a benched 600.1 did 617 w @ 4 ohms, and 712w @ 2 ohms. 1 ohm was not tested. It would benifit you (and your amp) better to go 4 ohm.
My bad.
I just looked up the bench results and I hate it when I'm wrong.
Thanks smgreen20.
615.2 @ 4 ohms
722.5 @ 2 ohms
I don't know what the 1 ohm power is.
I thought that it lost a lot of efficiency at 1 ohm though.
Why am I posting on Christmas eve? Santa is almost here!
cooldudejz
cooldudejz
N.H.
smgreen20
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
