PG tantrum 1200.1 question
Correct. It DOES NOT have a regulated power supply. 12.5v = 250 x 1 @ 4 ohms, 14.4v = 1200 x 1 @ 4 ohms. Most have benched well over that at around 1400+ wrms.
aren't those suppose to be "cheater" specs? i know for a fact this amp does not drop down to 250 watts at 12.5 volts.
wth? 250? no way... //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
If it does, at 11 volts you should get the same output as at 14.4. If you can test it, go for it.Really wish I could afford that amp..
i really don't believe it is regulated but it puts out more then 250 watts. i've been reading in the pg forum and they say it puts out a minimum of 1200 watts at any voltage so i would say it would be regulated then. i wish you had the money too. //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
iceteebone
Banned
iceteebone
Michigan
iceteebone
