PG RSD vs. ID10v.3
Thumbs up to audioholic and to innsanes, I would speand $30 more bucks to get a ''10 oz elite matrix. Also if you question is which would sound better, idq V.3 all the way.
According to a bad seller I bought a Rsd from, I damaged an Rsd with by clipping it with a 600w amp. But some people say these RSD's are known to take over 1000w //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Also, good luck trying to find a way to get an Rsd reconed if you don't buy authorized.
which is possible.
somehow, subs with lower power handling can handle that amp, but not an Rsd? Either the rsd isn't capable of handling at most 600w, or it had quality issues to begins with.. oh well
either or, I'd go w/ the ID over the Rsd if anything does happen. ID has great CS and can recone an ID with no prob if need be.
What happened with the possibility you were giving it a clipped signal?
All these said about the Rsd taking abuse of 1000-1500wrms, and a "supposedly" clipped signal from an overrated 600w amp (with gains low, set by ear) damaged it? ... I'm not sure about that....
If someone would choose to go w/ the Rsd, I highly recommend they buy authorized, so they won't have the same problem I had w/ it.
innsanes
innsanes
HB Cali
James Bang
