Peel And Seal
I live in Yuma, Az and we regularly hit 120 F during the summer. Will Peel and Seal work here? I would like to se if anyone has put it to these extremes yt cause i know that the trunk is going to go above te 150 f temp that the company recomends. Also Ant could you hit me up with some prices for SS??
sure
I will send you a PM
an easy test
put a few different samples on a cookie sheet. stick it int he oven upside down and set it to 150 degrees for an hour... see what happens with various products..
make sure you put tin foil under the cookie sheet. crank the temp up every 30 minutes untill you get product failure...
ANT
interior of a car, especially if it is not ventillated or cooled by ac gets much hotter than 140 degrees, and im just talking about air temperature, the metal gets much hotter, so my guess is that if u live in most part of the country during a sunny day, and ur car is left in a parking lot, the metal along with trunk and door panel compartments will reach above 140 degs... this is not to say that the product will fall off, since i havent used it, but i am interested in trying it. i work in construction so the truck will be left untouched for hours at a time while im working on site, so let that be the test
shicks007
shicks007
St. Louis Area
kungfoojesus
