J jollygt78 10+ year member Member 79 0 Ohion May 19, 2009 #1 i have 2 powerbass M-10D in a sealed box wanting to wire them 1ohm. would there ASA1500.1D amp be too much. the speakers are rated at 300rms 600peak. Click to read more...
jmanpc 5,000+ posts CA.com Nostalgist. 16,929 8 Jacksonville, Fl May 19, 2009 #2 uh, yeah. just keep your gain way down.
4OZGLOVES 10+ year member <--- Gina FTMFW 1,746 14 PITT. PA May 19, 2009 #3 Yes it is too much power,but if you set your gains well you should be fine and have room to upgrade when those subs don't do it for you anymore.
OP J jollygt78 10+ year member Member 79 0 Ohion May 19, 2009 Thread Starter #4 i was looking at the hifonics BXI-610 at 1ohm. i knew the powerbass was way more power then needed.
Brian_smith06 10+ year member I got a pan, I got a plan 4,624 5 Overland Park, KS May 20, 2009 #6 yeah however it leaves room to upgrade in the future. just go easy on the gain and you'll be fine. also for the money those are pretty nice amps. i just pulled mine out the other day and worked pretty well.
