Pavtube MOD Converter for Mac
This MOD Converter for Mac is an ideal tool for JVC MOD Camcorder users to edit and convert MOD videos on Mac OS. Its powerful edit functionalities allows you to personalize the recording video MOD from your digit camcorder in the way you like, and then output other popular video and audio formats like MP4, 3GP, AVI, MPG, MPEG-4, FLV, MOV, 3G2, VOB, MP3, FLAC, MKA, OGG, WAV, AC3, M4A etc.
Key Features
1 、Easy to use interface
You will be expert when using the MOD tool since its easy-to-use intuitive interface allows you to find any options you need.
2、Faster conversion speed
This program optimized its conversion speed, so that you can convert the MOD in less time
3、Simple gauss blur effect
Simple gauss blur effect is very useful to recorded file formats, since it can eliminate the recorded videos noise. The program allows you to add the effect, as well as other special effects like simple laplacian sharpen, gray, flip color, invert, aged film and deinterlacing.
4、Accurate trim the special length of MOD video
The trim function allows you to get the special length of MOD video accurately since its inner seek function can get the capture any key frame of the MOD.
5、Crop MOD clips
You can cut off the black edges and unwanted MOD video area easily
6、Merge multiple videos and replace original audio
You can join multiple videos into one bigger file for conversion, as well as replace the original audio with other sounds you like.
7、Add text, image, and video watermark
This program supports to add different watermark types, including text, image, and video watermark to the MOD. What is worth mentioning is that the program also supports to add GIF image as a watermark, which can not be realized by other competitors.
8、Capture the snapshot images
You can capture the snapshots images as your wallpaper or editing elements if you like.
9、Audio and video sync technology
The MOD Converter for Mac adopted advanced audio and video sync technology; never let you troubled by the audio and video issues.
10、Built-in codec
Its built-in codec will guarantee you a more stable computer codec environment, so as to less the unexpected codec problem.
Key Features
5、Crop MOD clips
10、Built-in codec
