Panasonic 7" inch wide color LCD TV/DVD-video/Receiver
-CQ-VAD9200U model
-$875 obo
-E-mail K925butterfly420@aol.com 979-324-2260
I have original box and paper work. Looks new and works perfectly. I can e-mail pictures. Brand new it cost $1649(internet) to $2499(retail).
-LCD Monitor 1 7" (diagonal) 16:9 wide screen color monitor
-High definition 336,960 pixels LCD Panel
-Fully-automatic open/close, flip up/down, and front/rear positioning
-Selectable 5 tilt angles and 2 horizontal positions with memoryNewAttribute4
-Manually adjustableleft/right swivel angleNewAttribute5
-One-touch tilt for easy access to air conditioner, etc.NewAttribute6
-TFT active matrix LCD drive
-L-shaped cold cathode fluorescent backlight and anti-glare coating
-Selectable display modes Normal, Full, Zoom, Just
-Automatic dimmer or 4-step manual dimmer
-Playable Disc Type DVD Video, Video CD, Music CD, and MP3 playback from CD-
R/RW discs
-ID3Tag information and CD Text display
-Ultra-miniature dual focus pickup
-Anti-shock memory and floating mechanism
-Automatic Disc Loading
-Amplifier Discrete 4-channel MOS-FET high-power amp (45Wx 4 max. at 16V)
-Center Channel Amplifer Dedicated center channel amp (35W max.)
-Private Mode Yes, during front/rear dual program playback
-High-precision D/A Converter 96 kHz/24bit
-Aluminum Diecast Heat Sink
-Dolby Digital® & DTS® Double Decoder 2
-Dolby® Surround decoder with Pro Logic® circuit 3
-Speaker Management
-Output Balance
-Delay Time (Dolby Digital, Dolby Pro Logic)
-Dynamic Range Compression (Dolby Digital)
-Full-Function DSP 7 sound field presets and "Multi-Channel" playback
-Graphic Equalizer 7-band graphic equalizer with 6 user presets
-Speaker Impedance 4 ohms
-Frequency Response 20Hz-20kHz, +/- 1dB (DVD)
-Distortion (PCM Input, 1kHz, 0dB) 0.01% (DVD)
-S/N Ratio 100dB (DVD)
-AM Usable Sensitivity (S/N 20dB) 28dB/uV
-FM Usable Sensitivity (S/N 30dB) 12dBf (75 ohms)
-Receivable TV Channels Ch. 2 to 69
-TV Channel Presets 18-channel auto preset memory
-TV Antenna 4-line diversity antenna (supplied)
-Radio Presets 12 FM and 12 AM presets with preset scan
-Auto Preset Memory Followed by Auto Scan
-Adaptive FM Front End (AFE)
-Impulse Noise Quieting (INQ)
-FM Optimizer (FMO)
-Digital Audio-in/out Optical
-Pre-Amp out RCA x 5ch
-Speaker Connector Front/Center/Surround
-CD Changer Control Terminal
-CD Changer-in RCA x 1ch
-VTR-in RCA x 2 sets for additional audio/video source
-VTR-out RCA x 1ch for rear-seat monitor
-RGB-in
-Preamp Output Level/Impedance 4v rms, 60 ohms
-Video Input/Output (Composite) 1.0V p-p, 75 ohms
-Audio Input Sensitivity 2V rms
-Security 4-digit ID Code
-Graphical User Interface (GUI)
-Multi-function joystick on front panel
-Beep on/off
-Full-function AV remote control
-Slim Design Hideaway Unit
-CQ-VAD9200U model
-$875 obo
R/RW discs
-Speaker Management
-Output Balance
-FM Optimizer (FMO)
-RGB-in
-Beep on/off
