i have a beautiful pair of XTANT 302a amps
both work as they should and look fantastic!
350$ shipped for the pair.
includes :
1 noise gate module
2 parametric eq modules
1rm8 module
a beautiful matched pair that i would hate to seperate.
Frequency Response 5 Hz to 50 kHz +/– 3 dB
Number of Channels 2
Watts per Channel @ 4ohms 2 x 75
Watts per Channel @ 2ohms 2 x 150
Bridged Mono @ 4ohms 1 x 300
Distortion (THD)
Signal to Noise Ratio > 100 dB
Damping Factor > 200 @ 100 Hz with 4½ Load
Input Sensitivity 100 mV to 8.5 V RMS Unbalanced Source
100 mV to 17 V RMS Balanced Source
Input to Line Output Gain 0 dB +/– 20 dB, Selectable in 10 dB Steps
Line Outputs: Yes
Module Ports 2 for Amplifier and 1 for Line Outputs
Crossover CM12HP Included
Power Supply Fully Regulated, Pulse Width Modulated
Operational Voltage 11 to 15 Volts
Fusing No On-Board Fuse
Fusing Requirement 50 Amp
Size (L x W x H) 14.5 x 7.6 x 2.25”
302a manual:
http://xtant.com/archives/html/techS...fs/302aMan.pdf
noise gate:
http://xtant.com/archives/html/techS...fs/NGM1Man.pdf
parametric eq:
http://xtant.com/archives/html/techS...fs/PQM1Man.pdf
rm8:
http://xtant.com/archives/html/techS...pdfs/RMMan.pdf
includes :
1 noise gate module
1rm8 module
Distortion (THD)
Line Outputs: Yes
302a manual:
noise gate:
parametric eq:
rm8:
