bgowdy
Heroes are remembered, but legends never die
PLEASE DONT GIVE ME THE ITS SKARBAGE, SKAM AUDIO ETC. I COULD CARE LESS ABOUT WHAT THE OWNER HAS DONE HONESTLY AS LONG AS THE EQUIPMENT PERFORMS WELL, WHICH I KNOW IT DOES.... ALSO DONT WANT OTHER SUB OPTIONS, JUST THE QUESTION AT HAND
Anywho, im thiinking about picking up a pair of Skar VVX V2 12s and run at .5ohm on my Soundstream Ta1.3000d.
Assuming the amp does 3k before rise(I'd say more like 2500-2700 average due to other tests I've seen on it). So ill assume after rize and voltage rhey will see roughly 800-1000 each(AMP WILL BE OSCOPED CLEAN). The ported spces on the subs say 1.75 - 2 cubes net. Seeing that I will be running alittle over rated should I be aiming for the minimum size for ported enclosure(3.5 cubes net/1.75 per) or should I aim for the middle (3.75 cubes net/1.875 per sub).
Don't need tuning or design help just curious how to determine the size. If needed to answer my question, my goals are a daily spl but still able to meter decent for the occasional comp.
Any help is nice and thankz
