PA microphone repair
89montero
I'm trying to fix the PA mic on my whelen(295HF100). Inside the mic's housing is the switch and a black cylinder connected by two wires, which is the actual mic. I figured it is that black microphone piece that is bad.
Does anyone know where I can get a new one of these?
I was thinking about looking for an old cb from goodwill or something and taking the piece out of there??
Whelen only sells the entire mic assembly and wants $130(not gonna happen).
Thanks
I've replaced the elements in a few electret condenser mics before, not too bad to do. I've had good luck with Heil Sound elements, but then again I was looking for something that'd work well with FM and SSB audio transmission, not quite PA use...
Do you know what kind of mic you're dealing with? Electret? Dynamic/ribbon?
I don't know what kind it is, I took some pics of it if it helps.
Mic assembly:
Case open, broken piece is removed:
Close up of broken piece:
Other side of broken piece:
89montero
89montero
Seattle, WA
89montero
