Pa A3000db
xluben
http://www.millionbuy.com/paka3000db.html
well, i decided to get this amp instead of a replacement soundstream pic1.1700d
anyone have any idea how much current it will draw at 1 ohm, and what power it'll put out?
i only need about 1600W, so it should be plenty, but i was hoping for a little headroom //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and my electrical is stock (besides big three) so i'm hoping it's reasonably efficient (it's class d, so it shouldn't be horrible... i hope).
comments?
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif just hope it lasts longer than the soundstream!
Sorry OT, but what was the problem with your SS? I was considering a 2 channel SS.
not quite sure, but it cause the fuse in my power wire to blow when the amp turned on. my other amp worked fine with the same wiring //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I think the pic1700 and the a3kdb are pretty much the same amp on the inside. So you should be able to plan on similar, if not the same performance.
the pic1700 i got is this one:
http://www.millionbuy.com/sospic11700d.html
it is definitely not the newest model //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
i think it's something they got on some kind of overstock/buyout and are selling pretty cheap.
it was BNIB, but a few years old.
after i returned it they said they have had quite a few of that model returned recently, that's why i went with the power acoustik.
at least they were nice enough to give me the heads up to a possible problem //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
also, i think the pic1700d has the same board as the pa2400d which i think is rated to do 1800W @ 1 ohm.
they both have all the same filters, and it looks like a similar case-style, so i assume it will be comparable, but hopefully a step up.
xluben
xluben
Minneapolis, MN
xluben
