OWNERS OF Cavaliers Help
Ricky616
Hi how do i replace my 6x9's that are located on the rear deck also i removed the door panels to replace the 4x6's with pioneer 5 1/4's but the right side panel is loose and when i drive on a bumpy road i can hear a rattle noise . Any solutions //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well its really simple actually.. your seat will fold down then u will see your rear deck which slides out... but be careful cuz i broke my seatbelt clips becuase they had mine glued to the window on accident.... jus pull and it will come. i also had to cut the speaker holes wider becuase my pioneers where to wide they where 6X9's though..
ABOUT YOUR DOOR MAKE SURE U GOT ALL THE CLIPS THAT ARE AT THE TOP BY THE WINDOW they are gold they connect the door and hold the seal to the window so theres no leaks sometimes it will make noise ifyou miss one and they are tricky to get them allsometimes....
if that didnt help jus reply and ill try to expain it better...
Ricky616
Ricky616
Chicago,Il
wlmrs
