chunky cumz
past due splooge
ok so i have the Power Acoustik 5500D finally!
But everone is like, "its overrated rms amounts"
I have 3 RE SE DVC 2ohm subs coming. Should i wire up to 3 ohm or 1.34 ohm.
3 ohm they will get about 2100-2000 watts rms (per the overrated figures)
1.34 ohm will get about 2900 watts rms (per the overrated figures)
ORRRR!!!
Just say fuk it and run it at 1.34 ohms and just keep gain real low? not sure if there are any disadvantages to doing this other than i hear that the higher the ohm the less quality(not sure if thats real true either, just rumor)
specs!
Amplifier Class D
Number of Channels 1 - Mono
RMS Power (4 ohms) 1700 watts x 1 channel
RMS Power (2 ohms) 2500 watts x 1 channel
RMS Power (1 ohm) 3200 watts x 1 channel
Bridged RMS Power N/A
Total RMS Power 3200 watts
Peak Power Output 5500 watts x 1 channel
Total Peak Power 5500 watts
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power .5%
Speaker Level Inputs No
Preamp Outputs Yes - 1 pair
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 50 - 150 Hz
Subsonic Filter 15 - 40 Hz
Signal-to-Noise Ratio 100 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 30A x 5
ORRRR!!!
specs!
Amplifier Class D
Fan Cooled No
Fuse Rating 30A x 5
