Orion HCCA 12"s D4
Vertex Audio
Pro Seller
Supporting Vendor
1,308
Los Angeles
2 Orion HCCA 12's
Dual 4Ohm. Cosmetic: 7/10 Working: 10/10. Has some paint wore off on edges . Beauty cover for magnet needs glued back on to bottom of one driver.
These have been tested and are guaranteed to work perfectly upon arrival or your money back. No questions asked.
12" Dual 2 Ohms HCCA Series Subwoofer
Power Handling:
Peak: 4000 watts
RMS: 2000 watts
Impedance: Dual 4 ohms
Polypropylene cone
Wide foam surround
Dual Flat Conex Spiders with Loop/Stitched Tinsel Lead
Field Replaceable Cone / Voice coil / Spider Assembly
4” copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
Enhanced voice coil cooling system (forced convection – aluminum heat sinking – shorting rings to reduce inductive heating)
Sensitivity: 84 dB
$350 shipped
$330 shipped for sub with the beauty cover that needs reattached.
Man if you caught me 2 weeks ago you would have sold these.... >.> Excellent price. Just heard a single 15" hcca today and i was impressed
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
781
I ran the Orion for about a year, then I bought the Taramps when I though the Orion broke. I found a knick in the Orion bass knob that was causing...
Ive had to install a 40 amp relay on the remote due to Popping issues on one my older Eclipse HUs, That ended up solving my popping issue. One...
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
Vertex Audio
Pro Seller
Supporting Vendor
Vertex Audio
Los Angeles
Dtrom
    May 10, 2024
3toneEYZ
    May 10, 2024
