orion 2500d switches n dials?
60ndown
seems theres a couple switches i dont recognise here, for normal operation of 1 sub with this amp where do i set the various switches and dials ? low pass 70hz , hp filter - no, gain-start low, but the others? also there is 2 sets of speaker terminals, are they bridged inside the amp or do i need to use both of them?
look on directeds website for the manual. it'll explain what each dial is for. and most amps if not all amps have 2 sets of rca jacks. one for input from the headunit and another for output to another amp. you want to use the input set. as for gain, set it to master (since you only have 1amp and 1 sub i'm assuming. i can explain the others if you want) and adjust the gain accordingly (use dmm). use the lowpass filter. leave the highpass filter off. leave the phase switch alone, and leave the intelli q alone (bass boost=fried sub). also, the speaker terminals are bridged internally (easier/cleaner to install multiple subs). use 1 set (if you have just 1 sub).
i'm pretty sure that's it. can't remember for sure.
*edit* link to intallation manual http://www.directeddealers.com/manuals/ig/orion/G47395.400.405.410_11-04.pdf
60ndown
60ndown
ca
dkguitarist
