Orion 1200D too much for my subs?
Peanut1181
Just a quick question...
I will be running two subs with the following specs each:
Single voice coil
4Ohm
250w rms
500w max
I will use the Orion 1200D to power them. Specs are as follows:
1 X 425 @ 4 Ohm
1 X 725 @ 2 Ohm
1 X 1200 @ 1 Ohm
I plan to wire them to run @ 2Ohm. Everything should work out well, right? That 725w @ 2Ohm will be spread out over 2 subs so it is ok isn't it... or not? Just a little advice would be very helpful. Thanks a lot.
Wow, thanks for the quick replies fellas. The subs are some old MTX Blue Thunder Legend 12" that I've had for years. They are currently for sale b/c I'm looking to upgrade but they'll do for now. That's why I wanted the 1200D so it would give me a little room for something better later. Thanks again for the help!
Peanut1181
Peanut1181
Peanut1181
Virginia
Peanut1181
