Sold Optima, Kicker, Crossfire
stuckinok
Sick My Duck
Got some things i want to get rid of. Trade wise? nothing SPL but i will consider a much smaller battery like a HC800 but iam open to offers.....
Some blue Kicker Hyper Flex from the 1/0 amp kit that I cut into 5 pieces. Along with the fuse holder and a 300a kicker fuse. 60shipped I will not split up...//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
4ft 8in
3ft
1ft
2ft 5in
10ft
I have a near mint Crossfire VR354 4ch amp that does 35x4@ 4ohms but that a 12v rating so expect near double that at 14.4v 60 shipped
Bridgeable 4 channel amplifier, 35Wx4 RMS, 280W Max., Variable highpass/ Lowpass Crossover from 50 to 500Hz for both Front and Rear channels, 2ch/4ch input switch, Input sensitivity selector switch, 5-way protection circuits, Nickel plated connectors, MOSFET power supply, 2 ohm stable. 9.3"W x 2.1"H x 10.5"L
My Optima G31 is back up for sale since the OG buyer has problem with paypal at the moment. Comes with the buss bars and the resting voltage is 12.7X 150 shipped
Optima Specs
Specifications:
• BCI Group Size: 31 (3/8" Stud)
• Voltage: 12
• Cold Cranking Amps @ 0 F: 900
• Cranking Amps @ 32 F: 1125
• Reserve Capacity Minutes: 155
• Amp Hour (20 Hour Rate): 75
• Weight: 63 Lbs
Dimensions (Maximum Overall):
• Length: 12 13/16"
• Width: 6 1/2"
• Height: 9 3/8"
Thanks guys
Jose
**** it I'll add this also It's a BNIB OZ Audio Matrix Elite 12 Dual 4. Sick woofer here guys. On par with the IDMax, ARC audio Flatline and other high end SQL Woofage I have two but iam only going to run one. 200 shipped Firm. I know what this sub can do and I rather keep it then let it go for crazy cheap.
Diameter 12
Impedance Dual 4
Power (RMS/Peak) 700/1400
Sensitivity (1W/1M) 86db
Frequency Response 20-500
Xmax (mm) 25
Fs (Hz)(2 ohm/4 ohm) 33/34
Mounting Depth 7.125"
Mounting Diameter 11.125"
Voice Coil Diameter 2.5"
Optima Specs
Specifications:
• Voltage: 12
• Weight: 63 Lbs
• Length: 12 13/16"
• Width: 6 1/2"
• Height: 9 3/8"
as for fitting a galant?...... hell if I know man i never been i\under the hood of a galant
I can bet it won't fit a galant, but check ur stock mounting location specs anyway, i could be proven wrong... and you could always throw it in the trunk and have even more reerve capacity
stuckinok
Sick My Duck
stuckinok
Rio Rancho, NM
stuckinok
NorthFramingham
    Jun 30, 2026
