Open Air Enclosure
cas0586
4
WV
Well not sure that is the correct term to use but looking to buy/build an enclosure for an old 10" MTX Thunder 4000 subwoofer. This subwoofer will be used outside around the swimming pool and fire pit. I will be using an old Directed Audio Extreme XA-5001 and xBox 360 power adapter to power the amplifier(12V/200W). Not the best equipment but this is what I have laying around for this project!
Should I be using a sealed or ported enclosure for this project? Stick with the manufacture specs for enclosure?
Thanks!
Usually I would say go ported all the way but from what I have read, ported enclosures only work good in enclosed areas like cars and rooms. I think it may not sound as loud in open air. I'm not 100% positive but would like to hear other opinions as well. If you end up going with sealed, I would try going on the bigger side like 1.5 cu ft to get the most out of it.
MDF is about $30 and truck bed coating is about $10 a can. I'd say it is about the same but can make a larger enclosure with 4x8' MDF. Time has to also be factored in as I already have enough time in the project. This is going to be a tow behind enclosure for tricked out RC power wheel... so there are still space and weight constraints.
Sounds ******! Got any pics of the tricked out rc?
Not many still in progress...
cas0586
cas0586
WV
cas0586
vegang
vegang
