One voice coil giving a higher than normal Ohm reading?
  • 4
I doubt its blown but its a little odd that the vc is reading about twice as high as the others. Could be a bad tinsel connection somewhere along the line. I had a similar issue with a sub from Sundown and they told me it was fine and I wouldn't notice a difference under normal listening conditions (skeptical of that myself) and refused to warranty it . Hook the sub up and give it a shot. See how it does.
its gonna need a recone because the voice coil is damaged or the lead connection as spooney said.
the winding could have rubbed and got damaged...
Well I don't know how to do a recone, and it would probably cost as much or more to get it reconed by someone else as it would to just replace the sub. I'm still going to hook it up and see if it works. I'll update when that happens, hopefully some time this weekend.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
676
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
998
Not to deflate your ambitions, but here is a reference: https://www.simplyspeakers.com/Altec-6-x-9-3-Way-Auto-Speaker-Sold-Out_p_639.html Not...
Justinw303
[Space for Rent]
Justinw303
Silver Spring, MD
Justinw303
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
