One More question - Filters, etc.
  • Thread starter cerebus1
  • Replies 0
  • Views 297
cerebus1
13
VA
Ok, thanks for all of the great information so far...Here's what I've come up with:
Phoenix Gold Octane R 5.0 4channel Amp
Polk Audio db Series db104 Subwoofer
POLK Audio db690 6x9s
Ill bridge 2 channels for the amp and put the 6x9s on a 80w channel each.
I plan to use a line converter to get RCA plugs to the am because the stock h/u doesn't have pre-amp outputs. The amp is supposed to have 12db HP / LP variable crossovers and a Low pass level port. Questions:
1) I think that the crossovers will allow me to to send mids and highs to the door speakers and lows to the subs, is this right?
2) Depending on whether I'm right in #1) do I need to put any of the bass blockers and what not on the speakers?
3) What is the Low Pass level Port?
4) When I splice into the line, I assume I want to use the line that the factory 6x9s are on so that I get a much fuller range signal to the amp?
5) How poor of a substitute for a preamp RCA is the line converter?
6) Since I'm sending 80w to the 6x9, do I need to replace the factory speaker wire?
THANKS SOOOOOO MUCH
Doug
cerebus1
cerebus1
VA
cerebus1
