OP
billybrown66
- Thread Starter
- #61
well, i might be wrong but... if i was running my components up front actively OR passivly i wouldnt be able to use time alignment OR tune them seperatley because they are all put into one category according to the head unit:"FRONT". therefore with the 860 or with x889, the only way to run have complete adjustability over all drivers would be with running:If you are using the passive crossovers for your components, then you can not run time alignment for the tweeters and mids independently, but rather you are running T/A for them both at once. If you are still planning on using passive crossovers for your fronts and rears, then you would be fine with an 860. Running active is when you ditch the passive crossovers and amp each of the components individually.
ONLY components up front and a sub
ONLY a set of speakers up front, rear fill and a sub
not to be a difficult, but i would think that most people who just go to shops to get equipment installed by the car stereo shop would get components up front, speakers in the rear door and subs in the trunk. so i wonder what head units they would use for those systems and how they would tweak their system if they didn't have the ability to tune each driver indivdually (not including subs.) seems like someone would have come up with the idea to make a souce unit capable of tuning comps for the front stage, rear fill and a sub that doesn't cost 1400 dollars new. maybe i'm asking too much....eh probably.
edit: not to take away from each of the units, because they are BOTH great decks for a great price. does anyone know if the eclipse 8455 or alpine 9855 can do this?
