Enough + 6
j/k...
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
Mode : AB
Number of channels : 5
Nominal power in 4 ohm : 4 x 60 W
The stereo channels can be connected in bridge mode giving a power of 2 x 200 W RMS
Nominal power in 2 ohm : 4 x 100 W
Mono channel, nominal power in 4 ohm : 300 W
Mono channel, nominal power in 2 ohm : 440 W
Mono channel, nominal power in 1 ohm : 600 W
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,3 - 7 V
Filter ch. 1 & 2 : Highpass: 80 - 400 Hz / 1,6 - 8 kHz (x20)
Filter ch. 3 & 4 : Highpass: 80 - 400 Hz. Lowpass 0,3 - 4 kHz / 3 - 40 kHz (x10)
Filters mono sub channel : Lowpass: 50-125 Hz.
Terminal for external cooling fan : Yes
Phase control : 0-180 degrees continuously
Remote sub level control with phase shift : Yes
Dual DC-inputs : No
Current draw, idle : 1,1 A
Current draw, maximum : 120 A
Dimensions W x D x H : 605 x 240 x 73 mm (23,82 x 9,45 x 2,87 inch)
Weight : 8,1 kg ( 17,86 lb)
