Omg.. What do I Do Ive Got A Problem..
So its a 5 channel!Could be in the connections but that should make everything shut off if it goes into protect.And it only does it when you turn the system up and the subs bang or can you disconnect the sub turn the volume up and get the same thing?
when i pull the rcas from the sub i can turn the mids all the way up fine, as soon as i plug in the rcas for the subs they throw the mids into protect. off and on. it works with the level on the subs so low but there isnt any bump..
thx so much for responding...
^^^Its all one amp!If the voltage drops on that it would effect everything.It may be something internal.Kinda hard to diagnose without being there.
no its not the same amp //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Da64u
Da64u
Fort Lauderdale, FL
Da64u
