omg i cant figure out what i want to run!
GCAdidas13
heh.
i want it to be loud
i want it to have good sound quality
i want it to be moderately easy to install
i want it to have a significant amount of midbass
i want a two-way frontstage suggestion, 60/40 SQ/SPL
Lets call the budget somewhere around $600 max for just the speakers
Suggest any of the following
midrange
midbass
horns
ribbon tweets
traditional tweets
component sets
DIY comps
Info section:
-Amplifiers
*Precision Power PCX4125 - 4x125w@4ohms, or 2x500w@4ohms
*Precision Power PCX440 - 4x40w@4ohms, or 2x160w@4ohms
(These are the amplifiers that I have, and I will need to keep these amps and not have to get anything else)
-Enclosures
*I can build kickpanels up to probably 0.3 or 0.35 cubes net (depending on driver size)
-EQ/Crossover
*After deciding on which speaker setup to go with, I will buy an EQ and/or Crossover to suit the speakers.
In order to generate some response, I'll mail out some cash to whoever suggests the product(s) that I end up buying.
PLEASE HELP!! !!!!
Thanks
Brian
Used ID CD-2 or Illusion CH-1 horns
RE XXX mids
I'm currently running AC G2Si ribbons.
It's relatively loud, but my CH-1 horns ***** them in volume. However, the horns were harder to tune.
Used ID CD-2 or Illusion CH-1 hornsRE XXX mids
Interesting... and how did the horns sound when compared to a traditional component set tweeter?
Horns practically have infinite volume (considering you'll never reach their max volume or you'd be deaf). They get incredibly loud while still staying clear as hell. Imaging is easier than a conventional tweeter also.
I was using the Illusion CH-1 fullbodies. I had them in for a couple months, sold them because I got tired of the lack of footspace resulting from installing them. MAKE SURE you have the space to fit them. I was giving them ~25w from my DLS A5, which is plenty of power for them. Crossed over at 2khz, 24db/oct slope I think. I just used the EQ/xovers on my HU, which is ehhh. Highly recommended that you get a 30band EQ if you want to do horns, and an RTA too. Squeak can give you a lot more info about them as he ran a set also. req has the ID horns IIRC, so you can ask him about those (which used to belong to audiolife I believe, so you can ask him about them)
i want it to be loudi want it to have good sound quality
midrange
midbass
horns
ribbon tweets
traditional tweets
component sets
DIY comps
Info section:
-Amplifiers
-Enclosures
-EQ/Crossover
PLEASE HELP!! !!!!
Thanks
Brian
midrange.... get 2 (in doors)http://www.usspeaker.com/beyma%206MI80-1.htm
midbass..get 2 (kickpanel)http://www.usspeaker.com/beyma%208BR40-1.htm
traditional tweets...kicker r 19 or r22 or r25
get this passive xover for the tweets and the 6.5 midrange
http://www.usspeaker.com/Beyma%20BASS%20Xtreme.htm
(scroll down until u see the asf2v 2way passive xover)
amps
one orion 4002 for the 8's
one orion 8002 for the midrange and tweets with passive 2way xover
eq audio control eqx or alpine ere g180
80
thank me later
midrange.... get 2 (in doors)http://www.usspeaker.com/beyma%206MI80-1.htmmidbass..get 2 (kickpanel)http://www.usspeaker.com/beyma%208BR40-1.htm
http://www.goemerchant7.com/index.cgi?ST=buy&Action=add&Merchant=usspeakerllc&ItemNumber=US!45B1167
amps
80
thank me later
duuuude thanks for the lengthy response... though...
i wanted to keep it simple... and i wanted to keep the amps that i have
with my old car it took up SO MUCH time and i hacked up the door panels (regretted it) and spent a lot of time perfecting crap that i made imperfect while doing the installation....
i would like to keep the amps i have and glass up a pair of kicks and install a set of tweets or horns or something somewhere for highs and call it a day
amps
80
thank me later
Pssst...he wants a Two way setup. He is also keeping his existing amplifiers.
But personally, I would put them in a bandpass tuned to 40hz with 2500 orion watts. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
67
GCAdidas13
heh.
GCAdidas13
Grove City, OH
hoss
