old school xtant a6001 cheap
stopdrpnro
Product Brand & Model:
xtant 600x1
Frequency Response: 20 Hz to 120 Hz +/– 1 dB
Number of Channels: 1
Watts per Channel @ 4Ω: 1 x 300
Watts per Channel @ 2Ω: 1 x 600
Recommended Load: ≥2Ω
Distortion (THD): ≤ 2%
Measured: 20 Hz to 120 Hz at rated power, all channels driven 4Ω
Signal to Noise Ratio: ≥ 100 dB
Measured: A-weighted in 20 kHz noise bandwidth @ 1 volt sensitivity
Damping Factor: ≥ 100 @ 100 Hz with 4Ω load
Input Sensitivity: 100 mV to 8.5 V RMS Unbalanced
200 mV to 17 V RMS Balanced
Input to Line Output Gain: 0 dB
On-Board Crossover: 24 dB/Octave Low Pass
Balanced Line: On Board
Power Supply: Fully Regulated, PWM
Operational Voltage: 10 to 16 Volts
Fusing Requirement: 80 Amp
Size (L xW x H): 15-13/16” x 9-1/4” x 1-7/8”
402mm x 235mm x 47mm
Subsonic Filter: 24dB/Octave 20-80 Hz
Bass Boost: 0-12dB @ 45 Hz
Condition of all items:
Amp works 100% they're couple small nicks, there are 2 missing screws on the back panel and one missing on the speaker connection but it's
mono any way //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif clean underrated power here
Total Price: :
$160 shipped i know one recently sold for less but i'm not in a crunch and don't need the $ .
Shipping Terms: :
shipping included to contig us.
Pictures: - Unless you are a Upgraded member, or your last 10 iTrader feedbacks are positive, you must post a picture of the exact item you are selling.
Additional info:
stopdrpnro
stopdrpnro
durham ,nc
stopdrpnro
