Sold Old School Soundstream Reference 705s 5/3 channel amplifier
Shinju
Putting this out there, was used for a short amount of time from the orignal owner back in the late 90's then stored away.
Soundstream Reference 705s 5/3 channel Class A amplifier.
If you want SQ here it is all 5 channels of it. Probably one of the hardest to find Soundstream amplifiers to this day it still holds high value.
This one is in absolute mint condition for its age with very very minor hair line scratches hardly noticeable it is used, 2 of the rubber grommets are missing for the dipswitches for the xover controlls other then that its a 8.5/10 almost a 9 imo.
All 5 channels work flawlessly, Loads of options for fine tuning see manual.
http://www.soundstream.com/manuals/AMP/REFERENCE/ref705s/ref705s.pdf
Asking 375.00 + shipping Trades, Looking for any Old School Phoenix Gold Must be in 8/10 cosmedic and 10/10 working condition.
Also please read the online PDF for anymore questions there is a ton of information to be gained I also have the orignal manual as well.
Specs are rated at 12v Amplifier has an unregulated PWM power supply so expect more at 14.v around 50watt gain maybe a tad more.
4 channel Satellite Outputs
50x4 4ohm
100x4 2ohm
100x2 8ohm
200x2 4ohm
Subwoofer Channel
High Power
200x1 4ohm
300x1 2ohm
400x1 1ohm
High Current
100x1 4ohm
200x1 2ohm
300x1 1ohm
400x1 1/2ohm
THD
Signal to Noise > 100 dB
Frequency Response 20 Hz to 20 kHz +/- 0.5 dB
Bandwidth 15 Hz to 50 kHz
Stereo Separation > 90 dB
Damping > 200
Input Sensitivity 100 mV - 2.5 V
Input Impedance 12 k ohms
CROSSOVER SPECIFICATIONS (all continuously variable):
2-way
High Pass: 12 dB/octave, 60 - 240 Hz
Low Pass: 24 dB/octave, 30 - 120 Hz
3-way
Tweeter High Pass/Midrange Low Pass: 12 dB/octave, 1 K - 4 KHz
Midrange or Midbass High Pass: 12 dB/octave, 60 - 240 Hz
Mid High Pass/Midbass Low Pass: 12 dB/octave, 240 - 960 Hz
Subwoofer Low Pass: 24 dB/octave, 30 - 120 Hz
DIMENSIONS:
19.0” W x 9.8” D x 2.25” H
Got to pay the bills!
Last one I saw go for in this condition was over 500.00 and it was missing all the rubber grommets on the bottom.
Great amplifier, If it doesnt sell no biggy. I got some other amps on the auction block maybe they will sell first //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I may take this. Got to sell my stuff first though...
Edit...what beast is undeneath the SS? Trade for a 9/10 Alpine H701?
Its 2 Stetsom TH amplifiers 2120 and 2250 under the SS.
Not really looking for a EQ, But what all does it come with?
701 has everything minus the optical cable. Harness, original box and manual, Ai-Net cable, and coax cable. I just got it, but am probably going to pick up a bitone now, but your amp is a beauty!
Cool deal, See if you cannot come up with the cash, That alpine is a nice piece but I dont know if I would use it.
Yes this amplifier is a clean piece of equipment //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif if it doesnt sell I'll probably just use.
I might take some ampgut shots since there is not any on ampguts.com or anywhere else.
From the sound of it, After reading the manual its got one hell of a powersupply //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sweet amp man
this is exactly what Im looking for
but I dont have enough monies //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Well if I sell the 701 out right I probably won't pick this up. I would use it only if I trade you. If not I'll sell the 701 and save up for an Audison 5.1k...but I wouldn't mind having this instead.
This ought to be close enough, it's the limited edition Continuum.
http://ampguts.realmofexcursion.com/Soundstream_The_Continuum/
Yeah I forgot about the Continuum, I'll have to sneek a peek on the inside.
Both amps are the same spec so the board is probably the same just minus the CONTINUUM on the board.
Shinju
Shinju
Seattle
ciaonzo
