Sold Old School Soundstream 300-2 and SPL 10's BNIB
dave_damage
Soundstream Nut Swinger
I have here a like new Soundstream Rubicon 300-2 Looking to get $175 shipped. Was used for a few weeks on some comps. Looks 9.5 out of 10
* Fully regulated MOSFET power supply
* RUBI? (Rapid-Use Branched Impulse) proprietary power supply topology
* STACT? (STabilized Apex Current Topology) Reduces power supply stress by 50%
* Trident? amplifier protection topology
* Hawkins Bass Control? Proprietary bass equalization topology
* IDI? (Intelligent Distress Indicator) gives visual indication of amplifier protection status
* Harmonic Bass Alignment? produces tighter, more accurate bass
* Power Grid? design optimizes current delivery to and from the power supply
* Chassisink? Semiconductors are situated between the circuit board and heat sink for optimal heat transfer
* Ultra-Low ESR Capacitance Bank ensures rapid power delivery for dynamic peaks
* Drive Delay III? A 3-second power supply delay to eliminate "turn-on" pops
* Auto High Current? matches the amplifier to virtually every load application
* Differentially Balanced RCA Inputs optimize noise rejection
* Fully Balanced PS-2 Input for the ultimate in noise rejection and improved S/N Ratio when a BLT or BLT4 is used
* Continuously Variable Low and High-Pass Crossovers
* Independent L/R, continuously variable input gain controls
* Symmetrically discrete balanced Class A drive boards for linear performance while driving low impedance loads
* Platinum RCA Inputs and Outputs
* Platinum Power Connectors
* Line Outputs
* Tri-mode operation
* RUB300-2
* No. OF CHANNELS: 2
* OUTPUT (watts):RMS @ 4 Ohms 75x2
* RMS @ 2 Ohm 150x2
* RMS Bridged @ 4 Ohms 300x1
* T.H.D.: >0.05%
* SIGNAL TO NOISE RATIO: 10 - 30k
* DAMPING FACTOR: >100dB
* FREQUENCY RESPONSE: >200
* INPUT SENSITVITY (VOLTS):: 0.3 - 5.0
* CROSOVER SLOPES:
* High-Pass 12dB
* Low-Pass: 24dB
* CROSSOVER FREQUENCY: High-Pass(Hz) 70 - 160
* Low-Pass(Hz) 55 - 220
* DIMENSIONS (INCHES): 2.25x8.5x12
Up next I have 2 Brand New Soundstream SPL 10's Looking to get $125 shipped each. link to manual http://www.soundstream.com/manuals/sbw/sp101215/sp101215.pdf
dave_damage
dave_damage
Gary, Indiana
dave_damage
