Is this considered old school PPI?//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif I want old school PPI.
Is it still for sale (I thought it was spoken for, let me know)? That is technically not considered an old school PPI. The two models (gun metal/ chrome or art series) before them are considered old school.Is this considered old school PPI?
... its for sale btw //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
You're not listening to me. He's not underpowering them at all. 400 watts total for the set of 3 will get all they have to give at lower freqs. I have experience from which I am speaking. It only takes about 120 watts each to get them to Xmax in a sealed box. If you don't understand that rated power handling isn't usually the limiting factor, especially in a sealed box then you have a lot to learn about the reality of car audio.Right now as long as my assumption is correct he is putting 400 watts total to all 3~ 130 watts each. Switching to the 2350 would give him 1400 watts for all three ~ 450 each. He is underpowering them now, and the 2350 could overpower them if the gains are not correct. It really is a toss up but I remember back in the Art Series day many people were running a triplet of the W6's with an A1200. Now I now that is only 1200 watts compared the 2350's 1400 watts but as long as the gains are set properly he should be alright(I am also assuming a sealed enclosure)
my bad man yea its spoken for, let me fix that last post //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifIs it still for sale (I thought it was spoken for, let me know)? That is technically not considered an old school PPI. The two models (gun metal/ chrome or art series) before them are considered old school.
Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifmy bad man yea its spoken for, let me fix that last post //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Speakers have mechanical as well as thermal limits. The thermal limits are what is listed in the specs for the sub. The mechanical limits are dictated by the size, type and tuning (for ported or bandpass) of the enclosure hat the subs are used in as well as the frequencies being played. The two limits are independent of each other and exceeding either will damage a sub. The 10W6 were very efficient and needed hardly any power to reach their mechanical limit at low frequencies. The cone of the sub travels as far as it can and powering beyond that will either add a ton of distortion, bottom the sub out causing damage or both.While I will freely admit that my knowledge of the finer details of how speakers work is not as vast as many's the original poster asked if the subs would sound different with that particular amp. My response was that they would probably be louder. I still cannot see, maybe I am completely missing the boat here and if so please excuse my ignorance how doubling the power will not make the subs sound louder. I have switched amps to a more powerful one while keeping the same sub and enclosure and it was louder. Granted I was not using W6's I was using D Series Solo's. Regardless in the end we are going back and forth for no reason as the original poster has not chimed in since his original comment.
well I am going to make some assumptions here and say that the PC1400 is the gun metal gray one(97/98 series) that puts out 800x1 at 2 ohms(or 400x1 at 4 ohms), and that you are running the older W6's(DVC 6 ohms) in series-parallel resulting in a 4-ohm load. If that is the case than it is a no-brainer, get the PC2350! The 2350 will give you 1400 watts at 4 ohms so it should be a good amount louder than what you currently have(subs are probably only getting 400 watts). Sound quality should not differ too much as the amps are both from the powerclass series.
