Old School PowerBase
07BronzeFuz
DueceEDuece
Guys just picked up 2 POWERBASE ES12D EVOLUTION SERIES 12" DUAL 4-OHM VOICE COIL SUBWOOFERs. I see some specs on sealed. like .85 cu ft per woofer but I want to port them. Anyone ever use these in a ported box? These are the older chrome evo series.
Here are some specs
PARAMETERS
Fs : 29Hz
Qms : 6.1
Vas : (Liters) 76.4
Qms : 6.1
Qes : .43
Qts : .40
Nominal Imp (Ohms) : 4 ohms + 4 ohms
SPL 1w/1m (dB) : 89.9
SPL (2.83V/1m) : 95.1
X-Max (mm) one way : 9
Pe - RMS : 450 Watts
Pe - Maximum : 900 Watts
Someone want to spec out a box for me. Smallest ported will do. I can give dems of the trunk I know it cant be more then 35 wide and 14 tall. Depth is what ever but like i said smallest box possible while holding decent sound. Looking more spl.
07BronzeFuz,
I had a pair of PBX es12d's in a ported box. 3/4" MDF with exterior dimensions of 36"W x 22"D x 14"H which has an internal volume of about 5.2 cubic feet. 2 4"dia x 12" vents. Open interior with blocked inner corners, 2 sections of cross bracing, seams air-nailed and poly-glued, covered with formica (seams covered), then covered with auto carpet. Heavy hog! Flat down to about 48Hz and hits 28Hz (-3db). I wired the subs DVC's so the amp saw 4ohms powered by an Infinity 1211A (850w RMS @ 4ohms). Takes a large box...was in the back of my Buick GN....car & sound were head turners!
wow 43 looks and no one replying!
Probably cause they are all coming in here trying to figure out what old school and power bass have to do with one another. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
07BronzeFuz
DueceEDuece
07BronzeFuz
Nashville North Carolina
ramos
