PLEASE, DO NOT CONFUSE THESE AMPS WITH THE NEW XTR SERIES, AS THESE ARE TOTALLY DIFFERENT AMPLIFIERS... and frankly, EXPONENTIALLY BETTER.
Ok. So... after much thumb twiddling, i decided on selling the following amps:
Here are a matching pair of XTR dual mono-block amplifiers. They are exactly the same (as you will see in the pictures) as the NT series amplifiers, aside from the red marbling instead of purple marbling in color.
If you don't know what these amplifiers are, then you should take some time and go read the manuals on Orion's website. Link to manual http://www.orioncaraudio.com/Support/Manuals/Amplifiers/XTR%20Series/Orion%20XTR200%20Installation%20Manual.pdf
But here are the specs for those that are cliff-notes kind of people:
XTR/NT100
Power: 50W x 2ch @ 4ohm on 12V battery [rated]
100W x 2ch @ 2ohm on 12V battery [rated]
200W x 1ch @ 4ohm on 12V battery [rated]
400W x 1ch @ 2ohm on 12V battery [rated]
800W x 1ch @ 1/2ohm on 12V battery [rated]
THD: 0.005%
Slew Rate: >500 Volts per microseccond
Output Damping: >1000
S/N w/balanced input: 112dB
Power Bandwidth: 6Hz to 1000kHz +/- 5dB
Idle Current: 1A
Full Power: 28A @ 13.6V
XTR/NT200
Power: 100W x 2ch @ 4ohm on 12V battery [rated]
200W x 2ch @ 2ohm on 12V battery [rated]
400W x 1ch @ 4ohm on 12V battery [rated]
726W x 1ch @ 1.15ohm on 12.5V battery [measured]
983W x 1ch @ 1.15ohm on 14.4V battery [measured]
THD: 0.005%
Idle Current: 1A
PRICES: Obviously, I will entertain REASONABLE offers, low-balls will be... not
XTR100 - $750
XTR200 - $750
NT200 - $600
Flash shows dust that isn't even viable to the human eye, I don't know why it still shows up.
NT200 with scratch in top/center of heatsink //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif but it still plays like a monster on steroids //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
By the way, I am not going back and putting a stupid piece of paper with my name on it, if you don't believe i own these amps... I really don't care, because I do (I own 9 of them to be clear). I just forgot to make a magic piece of paper with my name on it for before I took the pictures, ooops, and oh well. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif If you'd like to check on my history PM me and i will give you credentials and referrals, I'm assuming that I've been on here long enough, and made enough purchases to be taken seriously and not be low-balled and treated as a newb.
thanks for looking.
XTR/NT100
THD: 0.005%
Idle Current: 1A
XTR/NT200
THD: 0.005%
Idle Current: 1A
XTR100 - $750
XTR200 - $750
NT200 - $600
thanks for looking.
