Old School Earthquake PA-2300
arsonbob
Earthquake PA-2300 Amplifier
Specs as copied from amp guts:
2 x 300W @ 4 ohms
2 x 550W @ 2 ohms
1 x 1150W @ 4 ohms bridged
THD: 0.015%
S/N Ratio: 110dB
Built by Zed Audio
Perfect working condition. One of the terminal screws is missing but can be replaced (shouldn't be that hard to work out). The amp is old and has scratches here and there. The mounting holes are missing 3/4 of the rubber grommets. Other than that, everything is good to go. I never had an issue with it and have been running it for two months after buying it used locally. Reason for sale is that I no longer have a vehicle to run this equipment in.
$180 (not sure what they run), also not in a huge hurry to sell it though.
I would much rather sell this locally.
Nice amp! I would offer up if I didn't already have one...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
BTW, the 4 ohm rating is 380x2 at 4 ohms, despite the 2300 model. Here's the full line Earthquake sound amp manual from 1995:
1995 Earthquake Sound Amplifier Manual - PA-2020, PA-2030, PA-2040, PA-2040c, PA-2050, PA-2075, PA-2150, PA-2300, PA-2075c, PA-2150c, PA-4300, PA-4030, PA-4020c, PA-4050c & PA-4100c (if you found this from a search engine, you're welcome...the manual is 9.3MB in size and took 30 minutes of my time //content.invisioncic.com/y282845/emoticons/highhorse.gif.6bbb570c3f53dc0dcce8a2b8ad05cf11.gif)
I haven't benched mine for output yet, but this amp is powerful and should put out as much as a HiFonics Zeus VII or VIII. GLWS, somebody should snatch this joker up!!
Do you happen to know if this is 2 0hms mono stable??Some were back in the day,just as the Autotek BTS series.By the way..I enjoy your YouTube sig If you are that Guy??Old School Audio?
I would say no for this PA-2300 and 2 ohms mono. Yes, some of the Autotek BTS amps were 2 ohm mono stable, but this amp is not. And yes, I am BigDWiz on YouTube and OldSchoolStereo.com. You haven't sold this amp yet? Wow, I'm shocked //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
I thank you sir for the Info..I enjoy your Program..Would mind getting with you on tilting out/testing out one of my Mean Machine 99s for true output,and spec sheet
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
arsonbob
arsonbob
Riverside, CA
arsonbob
Decebal
    Jun 10, 2024
