mjoekingz28
Say you have two 4 ohm subs. You can run them straight stereo at 4ohm. Or you could series them to 8 ohms then bridge them, or you could paralled them into 2 ohms and bridge them.
I ised to hear alot that bridging causes the amp to see half. Is it possible to have a bridged load at stereo. I just sometimes wonder when I see power ratings like 100X2 @2 ohms and 200X1 @ 4ohm mono.
Mainly I am asking the correlation between mono and bridge.
I used to have a US200 amp and would parallel two 4ohm subs and then bridge them ( right positive left negative) and I assumed a 1ohm load. They were later replaced with two dvc 4ohms that were paralled into 1 ohm then bridged into what I thought was a 1/2 ohm load.
