OK,you have only 1500.00 to spend
Ignatowski
Need to build a system,medium budget of 1500 -
Limited to 2 - 8" or 10" subs & sealed box or 1 in ported box
Wires (4ga) , blocks etc
6.5 comps Front
6.5 Rears (RAF)
Max power 700@2ohm subs
100x2 comps
and HU
This is what I want to make for my new work vehicle which is a small 4 seater
which is limited in trunk space of a small hatchback
what would you build
Im looking for SQ more than SPL
Start with a killer deck. Splurge a little on the primary source of your audio indulgence. My reasoning, if you have a kick *** amp, the sound will still sound crappy if your head unit sucks. Also, with the right head unit, you can go with the components amped off the deck to save you some cash for later on. Go with a two 8" in a sealed box (sealed is generally smaller). Push the 8s with a decent amp (about 250-500 depending on the 8s). I would honestly look to spend close to $1000 for both the head unit and amp (with wires and patch cables obviously). That would give you $500 to spend on a couple **** good sets of components. Now, you can get a couple really good 8s for around $45 each (stay away from Best Buy and others... you'll pay too much for crappy equipment). The two 8s would give you the surface area just a tad larger than a 12 with a 3db boost if you put the subs in the same chamber (firing down). With the right amp, the subs could really crank... just not intended for SPL. You can get some good components for under $150. All you would need is a set for the rear... but if you want, go with an excellent component set up front and set the sound stage to the front of the car, ignore the back.
single 10. if ur going to go 8s, the RE8 or the image dynamics 8 are wonderful. talk to loyd, he did a "battle of the 8s"
pair of soundsplinter rl-i 8's or 10's 300 or so
alpine 9833 300 or so
eD nine.1 350
eD nine.2 175
eDi 6500's, diamond hex s600s, cdt's, etc, 200-300
1/0 awg wire 30
distro block 10
rca's 10
box- 30-50
Total is right around 1500 and that would be one hell of a system.
god ****, there's more out there than soundsplinter. oh well, i guess its just a new phase.
have you SEEN those eights? //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
the setup he just listed - if i had $1,500 to setup a system - id do it in a heartbeat considering your specifications.
//content.invisioncic.com/y282845/emoticons/satan.gif.9c6a335ed7aeeed3ee273e573f1fcaac.gif//content.invisioncic.com/y282845/emoticons/satan.gif.9c6a335ed7aeeed3ee273e573f1fcaac.gif
Ignatowski
Ignatowski
Dirty South
eric77
