Ok this will make my decision 1 Crunch 3000 pro or 2 Kicker zx1500.1
Search the crunch amp on here. And then go on dbdrag forum and search it on there. Alot ALOT more ppl use the crunch amp on the dbdrag forum then here.
But shoot for 900 search around for a used stestom amp. Or DD.
Got to ask did you or have you done any research on the amps you like and just in general for amps that is in your price range before making this post.... I seen you have other threads about amps too. Get any feed back in those threads
Wait a minute what kind of subs are going to be running cause the kicker is 2ohm and 4ohm stable and the crunch is 1ohm 2ohm and 4ohm stable.
Im running 4 DC lvl-3 15's with the upgraded flat wound 2ohm coil and there going
in a chambered, dual ported box,( two subs per chamber). And scene there dual 2ohm subs I can wire two subs @ .5 or 2ohm Or I can wire all of them together @ 1ohm. So that is why I went with 2 Kicker's @ 2ohm's or 1 Crunch @ 1ohm
Oh yeah I for got ... These are my choices Kicker or Crunch Because I have enough to
get (One Chunch) or just (One kicker) for now...I dont want to save because I wont have any
beat until after February. I dont have the money for a sundown or DDm3 I would have to wait till income tax time
Well I called kicker today to ask about the 100 amp fuse on the 1500.1 He told
that they had 150amp fuse and two would be 300amps total ... I was thinking that
mabe the kicker's would be more efficient, because I thought they had 100 amp fuses
and there would be less electrical strain than the Crunch ....All this came about because
of this one pic http://www.sonicelectronix.com/item_7302_Kicker+ZX1500.1.html
It shows the amp to come with a (Kicker 100amp Main Fuse) So i put 2 and 2 together and assumed it was 100amp max amp lol Anyway looks like im going to be geting the Crunch instead
they make 2.9k on most birthsheets 500 watts is gonn abe a db or two from 2500-3k so save yourself some money and forget that crunch amp.
Yeah i would run the kicker but my wiring options keep me from it as I stated earlier I can run one 1ohm stable amp or two 2ohm stable amps
Ugh I guess I could just save my money and get one good amp
Like this... It was my first choice I'll just have to save a bit longer
Iv never heard of this brand until I became a member here... These are solid amps right:confused: Before I go out and buy one //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
http://www.audioque.com/aq/AQ3500D.htm
Jeepjones85
Gold Power
Jeepjones85
South-East AR
Jeepjones85
