Ok need help I keep hearing distortion from Sub
Jeepjones85
Gold Power
Ok just got my like new Rd 15 in and I wired it down to 1ohm to my powerbass 3000d. And here is the problem. Whenever I turn it up and the sub hits higher bass notes I can hear distortion, or what sound like it. But it hits the lows fine nearly braking my truck. The voltage does not drop down below 13v and My cd player
is set to 0 bass on the Eq which it the half way mark, and the loud is on med
and the bass boost is off. And the amp's bass boost is off and everything from the radio to the amp is set a 50hz. And it still sounds like it's distorting....
Any Ideas.....
bass boost on amp is off and gain is half way... If i turn it down any more then I want be able
to hear any bass Ugh this is aggravating. Its already not as loud as it could be
Ok just got my like new Rd 15 in and I wired it down to 1ohm to my powerbass 3000d. And here is the problem. Whenever I turn it up and the sub hits higher bass notes I can hear distortion, or what sound like it. But it hits the lows fine nearly braking my truck. The voltage does not drop down below 13v and My cd playeris set to 0 bass on the Eq which it the half way mark, and the loud is on med
Any Ideas.....
One issue. And second - Half way isnt proper. A DMM, or better yet, a o-scope would be the best here.
Jeepjones85
Gold Power
Jeepjones85
South-East AR
Jeepjones85
