Well i been debating alot on what subs are for me but cant decide on what i want. So im looking into two subs at least two 12's or maybe 2 15. I want them to be loud enough to hear me from blocks away but at the same time i want them to sound great! I drive a 1994 Accord plan to get a custom fiberglass trunk dont care if it takes up the whole trunk. I was intrested in the alpine type x for a while cause i was gonna do all apline but changed my mind but i will still consider them, Also im intrested in the jl w6v2,Daimond Audio D9,Kicker L7,but i be willing to take suggestions... MY buget well i dont really have one but dont want to expensive cause i plan to save money every month just dont want it to be outrageous 2500 at the most thats for subs and amps and supplies. I listen to rap if that helps, and thanks for everyone that helps.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
mistake #1 never say you want a system that can be heard from blocks away, if you did that, you would be frowned upon or flamed, badly. First some members would give you a pep talk, then older members are going to tell you to stfu and go way...
anyways, since your new, i'll give you some suggestions...
$2500 max is a huge budget and it'll pretty much go to waste if you want a custom fiberglass job the size your describing. i'm guessing at the cheapest, a fiberglass of the size would cost you $2000 with labor, which leaves you with an average system...now this is what i suggest...
subs: kicker solo x - 2 for about a $1000 (crazy loud with right amount of power)
dd9915 or 2 dd 9912 under $1000 (still crazy loud and great quality)
2 si mag under $1000 (get hella low and good output in the right enclosure
2 fi btl under $1000 (new forum boner, great subs)
amp: something decent from hifonics or orion or anyother cheap power i forgot to mention
supplies- if you take my suggestion and go ported (you really should!!) then about 50 bucks for mdf, glue, carpet, tool all for under $150
now that is a system to drool over...
so your asking why not fiberglass? well fiberglass enclusures are not ported = less out put (bad for rap) and if you don't mind sacrificing the trunk, then you could do a huge as s poted box that would slam like crazy.
so think about it, expensive as h ell fiberglass or huge out put from $150 box? (besides, fiberglassing the entire trunk is for serious competitors making show vehicles...for looks...)
