soldiermedic
Noob4Life
Let me ask you all this: What would you recommend for a listener to build a box at with the specs for an Infinity Kappa Perfect DVQ 10" (for everyday use, not competition. Specs below) with a variety of music styles, ample trunk space, looking for a good fill without being too boomy? Also, when I use these box building programs, is it a bad thing to look for a flat response around that + or- 3db threshold? You know how sometimes you get that hump at the lowest range of the tuning? What is that, anyway?
Specs for my sub:
Perfect10d VQ
Diameter 10" (250mm)
Sensitivity @ 2.83V/1m 90dB
Power Handling 400W RMS/1600W
Frequency Response 25Hz – 400Hz 25Hz
Impedance per voice coil 4 ohms
Voice-Coil Diameter 3" (77mm)
Mounting Depth 6-1/2" (166mm)
Overall Diameter 10-1/2" (267mm) 10-1/2" (267mm)
Cut-Out Diameter 9-5/16" (237mm)
Basket Displacement .072 ft^3 (2.04 L)
Voice-Coil DC Resistance Revc 1.66 ohms
Voice-Coil Inductance Levc 0.8mH
Driver Radiating Area Sd .344 ft2 (.0323M^2)
Motor Force Factor BL w/MidQ Insert 9.33
Compliance Volume Vas 1.32 ft3 (37.65 L)
Suspension Compliance Cmd 254.13uM/N
Moving Mass, Air Load Mms 157.9g
Moving Mass, Diaphragm Mmd 154.56g
Free-Air Resonance Fs 25.13Hz
Mechanical Q Qms 10.24
Electrical Q Qes w/MidQ Insert .46
Total Q Qts w/MidQ Insert .44 .
Magnetic-Gap Height Hag 3/8" (10mm)
Voice-Coil Height Hvc 1-11/16" (43.5mm)
Maximum One-Way Linear Excursion Xmax 11/16" (16.75mm)
If you get an issue with errors in these numbers, I feel your pain. They're exact, though.
1. What freq should I tune the box to?
2. What is the most reasonable box size for it?
3. Do you like pie?
Bracing for the criticism....GO!
Specs for my sub:
Perfect10d VQ
3. Do you like pie?
