oil light coming on??
head gaskets do not leak oil they keep coolant from mixing in to the combustion chamber! valve cover gasket maybe but if they did the oil pump it's probably leaking from the pan gasket.
Yeah, thats what I thought too. That place is horrible, im never gonna take back to them. Also my car is running a lot smoother after flushing it like you said. thanks for help
It's all good man, I'm glad your cars running better for you and yea MOST mechanics really don't know what there doing unless it's a certified dealer and even they will cut corners! Go ahead and plug the sensor back in and see if it's holding oil pressure now. hit me back and let me know!
Oil light is still coming on but it goes alway after a little tap on the gas peddle.
Did they? I mean they obviously lied to you and told you they fixed the sensor when they just unplugged it. Can you actually verify that they did do the work?
They showed me the old parts like the old belts and water pump. It's leaking oil from the crankcase which is where they worked at. I know the owner and I told him that his worker unplugged the sensor and lied. He seemed shocked and said he's gonna talk to his worker and he said he's gonna personally fix it himself and fix the leak.
good going! don't let them f%$k you over!
myjaja
Audioque
myjaja
San Antonio, Tx Posts: 143,632 _____<^>*_*&l
myjaja
