ohms
ya i was just wondering because i sent an l7 to kicker for warranty work and they sent me a 2 ohm back instead of a 4ohm so i dont know what to do..
Technically nothing would self implode or catch on fire.
However, the subs would receive different amounts of power......which obviously is not a good thing.
If you received a recone back and they sent you the wrong/different impedance coils; I'd call Kicker (or your local dealer, if that's who you went through) and tell them that they sent you incorrect coil configuration.
yeah, getting two amps is one solution, but honestly, i'd try to get the voice coils made right. if you can't get a good resolution from kicker, then this may be your best option.
He is correct.
Once the power from the amp reaches the bridge between the two subs, there will be an impeadance difference, draw it up as if it was a circuit and you will notice. But like someone said, nothing will go wrong, things just wont work out right.
siddyboo
siddyboo
Canada
delvryboy
