Ohms/Lights Dimming
Decado
Ok, my question is, right now i have my amp doin 600rms@4 ohms and have barely any light dimming. If i upgrade to 1200 rms @ 1 ohms will that increase dimming? The reason i ask is because 1200 rms @ 1 ohm amps are usually rated at less than 600 rms @ 4 ohms. All in all what i'm asking is, does 1 ohm have more of a drain on power than 4 ohms, or the other way around?
SSS is correct, you will be fine. You may have some dimmage, especially at idle, but other than that there should be no problem what so ever.
Decado
Decado
Minneapolis, MN
Decado
michigan born
    May 14, 2026
michigan born
    May 14, 2026
