ohmmmm help
Ok take a wire and plug it in one of you negitives on your sub and plug it into the other negitive on the same sub and do the same with the positive on the same sub. Then get another wire send it to one of the negitives on the other sub. And do the same with the positive and send it to the positive and negitive on the second sub now take on wire and have your positive wire going to your amp and have your negitive wire going to the negitive on your amp now this is called wiring it in parrlell and you will have a 2ohm load.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Patrick
jl man must not ahve noticed you were trying to get a 2 ohm load, which cannot happen with 2 dvc subs 4 ohm per coil......you would need 2 more subs
jamesdean728
jamesdean728
san diego
gregj9
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
